Anyone use BGM Electronics Transducers? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=47956 |
Author: | jfmckenna [ Tue Jun 28, 2016 3:17 pm ] |
Post subject: | Anyone use BGM Electronics Transducers? |
I found this product today searching for light weight transducers and this feature seems to be a highlight of this companies offerings. I like bridge plate transducers like K and K but I also like to built guitars that are responsive as possible and retain as much pure acoustics as they can. They are obviously aware of this and have apparently designed a very light weight system. I'm just wondering if anyone here has any experience, comments, other suggestions etc... http://www.bgmelectronics.com/index.html |
Author: | Chris Pile [ Tue Jun 28, 2016 4:44 pm ] |
Post subject: | Re: Anyone use BGM Electronics Transducers? |
Never heard of them. |
Author: | Colin North [ Tue Jun 28, 2016 5:47 pm ] |
So you don't have any any experience, comments, other suggestions etc.. then Chris? |
Author: | Colin North [ Tue Jun 28, 2016 5:52 pm ] |
Well Mr McKenna, those sound like they may be worth throwing a few bucks at! I look forward to hearing any insights anyone may have. |
Author: | rlrhett [ Tue Jun 28, 2016 6:32 pm ] |
All I can say is that they look suspiciously like the fairly ubiquitous 20mm piezo disks coupled to a thumbwheel. Maybe there is some proprietary wiring on that thumbwheel? Don't know what they cost because their webpage appears broken. However their prices for just the jack and piezo is reasonable and pretty close to JJB. Certainly not a major investment to buy a set and see if "lightest in the industry" means the same as "nothing cleans better". |
Author: | Jim Watts [ Tue Jun 28, 2016 11:20 pm ] |
Looks just like K&K transducers also. The weight can't much different than a K&K. |
Author: | Fred Tellier [ Wed Jun 29, 2016 7:55 am ] |
I used a set and they are identical to K&K both in look and sound. I think the transducers are purchased from the same supplier as K&K. Fred |
Author: | meddlingfool [ Wed Jun 29, 2016 9:11 am ] |
Fred, Are you talking JJB, or BGM? Because k&k's weigh around 11-13g, as do the JJB, whereas the BGM ones weigh only 1.2g. Pretty significant difference. |
Author: | Chris Pile [ Wed Jun 29, 2016 10:51 am ] |
Quote: So you don't have any any experience, comments, other suggestions etc.. then Chris? Pretty sure I made a comment. |
Author: | jfmckenna [ Wed Jun 29, 2016 1:47 pm ] |
Colin North wrote: So you don't have any any experience, comments, other suggestions etc.. then Chris? In a way though Chris's comment is actually helpful. I have only found one third party review on the Acoustic Guitar Forum. So it suggests that perhaps they are unheard of for a reason? The reviews were good but some others are mixed. It might be better to let the market decide over the next year or so. But then for what the price is worth I might just give them a try too. |
Author: | meddlingfool [ Wed Jun 29, 2016 2:24 pm ] |
Probably worth knowing for sure your own opinion of them... |
Author: | rlrhett [ Wed Jun 29, 2016 4:06 pm ] |
The likelihood that they actually weigh just 1/10th of the JJB's or K&K seems low. There seems to be more than 1g of plastic rubber backing on each piezo. Still, I have an open mind. I would love to see what you find out. |
Author: | meddlingfool [ Wed Jun 29, 2016 4:46 pm ] |
I've weighed them. |
Author: | rlrhett [ Wed Jun 29, 2016 5:32 pm ] |
So you have used these? I was under the impression no one had tried them. So did the difference in weight make a difference in tone? What were your impressions on the sound compared to K&k? Did you like them? Would you recommend them over JJB or K&K? Sent from my iPhone using Tapatalk |
Author: | kencierp [ Wed Jun 29, 2016 5:49 pm ] |
Never tried them (BGM) --- but couple of observations, high quality piezo discs are two cent a ton whether pharmaceutical, brass nickel alloy or not, "really" just a few cents a piece, ones with starter leads cost a tiny bit more. Any of us that fooled around in electronics has seen this at various supply houses. I believe BGM and Archangel at one time, maybe still were working with JJB electronics. I recall reading that the potting material added to the back of the disk was considered an improvement I'm pretty sure Jessie at JJB could explain why. |
Author: | J De Rocher [ Wed Jun 29, 2016 6:49 pm ] |
meddlingfool wrote: I've weighed them. What was it that you actually weighed? Was it the whole system or a single transducer? The BGM site says one of their transducers weighs 1.2 g. I'm not buying their claim that that weight is significantly different from a K&K transducer since I just weighed one I have waiting to install and it was between 1.0 and 1.5 g. I also weighed a single Dazzo transducer I have waiting for install and it was also between 1.0 and 1.5 g. |
Author: | meddlingfool [ Wed Jun 29, 2016 7:54 pm ] |
Your best bet is probably to collect your own data. |
Author: | Jeffrey L. Suits [ Mon Aug 01, 2016 5:16 pm ] |
The claimed light weight may have as much to do with the skinny Mogami cable as anything. Which, BTW, is great stuff, even if it's not, "Pharmaceutical grade". |
Author: | Don Williams [ Mon Aug 01, 2016 6:59 pm ] |
I couldn't use them due to the way I use small finger braces at the sound hole. Looks like this requires a flat brace there, and I'm not willing to reduce the structure there to that degree. Just my $0.02. |
Author: | jfmckenna [ Tue Aug 02, 2016 10:09 am ] |
I use the same kind of finger braces. I would just be interested in the passive system anyway as I like to have all pre-amps external. But yeah that's a problem with any one of those style systems I guess. |
